Hi people!!!!!
right i need some serius help with Overclocking my system.
ive had it before clocked at 2.73Ghz and the memory which was 667Mhz at 772Mhz,it was Prime95 stable with the settings i had it at then,however.......
Now ive just purchased some new ram (OCZ 4GB (2x2GB) PC2-6400C5 Dual Channel Vista Gold Series DDR2)and defaulted all my clocks back to start fresh however i can still not go over 2.8Ghz it just fails within 1 minuite.
these are my settings in the bios
what am i doing wrong? i sometimes got bluescreens when booting up aswell
dunno if it has to do with memory timings or soething? surely i can hit 3Ghz?
these screenshots are default system speeds.
teh ram i purcahsed
http://www.overclockers.co.uk/showpr...odid=MY-086-OC
Adjusted CPU FSB Frequency [400] Adjusted Cpu Ratio [7] Adjusted Cpu Frequency [2800] Mhz .................................................. .................................... FSB/Memory Ratio [1:1.00] Adjusted DDR Mem Frequency [800] .................................................. ..................................... Cpu Voltage [1.3750v] Memory Voltage [2.00v] Northbridge Voltage [1.375v] Southbridge [Auto] |
teh ram i purcahsed
