Help me overclock
359 Views 3 Replies 4 Participants Last post by  MrPriest
My rig is
a780gm-a version 1.0
4 1gb sticks corsair ram finned i think 4-4-4-12
his 4870x2 2gb
corsair h50 liquid cooled
700 watt ocz psu
phenom 940 8mb
i run 3dmark 06 and get 17,100 with no over clocks what so ever. would it be possible to break 20k and what settings would i use? anyone familiar with this board and what timings i should use?
running xp black edition 32 bit.
i need help voltages, settings ram timings etc. please help if you are familiar with the mobo. i also updated the bios as well.
1 - 4 of 4 Posts
ok. first download prime95 (mersenne.org) install that. then go into the bios and increase the fsb by 5mhz. run prime95 for 30min. if it dosn't bluescreen, rinse and repeat. once it bluescreens, go into the bios and increase the cpu's core voltage by .025v return to increasing the fsb in 5mhz incraments, testing with prime95. once it bluescreens again, back down the fsb to the last stable setting and run in a longer burnin with prime 95.
(note: the original phenom has a cold bug, that prevents the cpu from being overclocked very far. i doubt that you can get the cpu to speeds in excess of 3.7ghz.)
I agree on Prime95, but not much else.
First of all the Phenom 940 is a Phenom II which overclocks fine.
Next its a BE CPU so I would suggest Multiplier overclocking as you don't have to worry about all your other components at the same time. You never mentioned in your post to lower the HT multiplier as well as the RAM speed, because they could cause instability if overclocked as well, keep in mind, with multiplier overclocking you won't have to worry about this as you will only be moving the CPU multiplier, thus only OC'ing the CPU.
For a technique:
Raise the multiplier by .5x
Test with prime95 for 30min (watch your temps!)
If no BSOD nor errors, raise multi again .5x
30min prime 95. (watch your temps!)
Repeat until you get BSOD or an error.
Raise the voltage by .25V and try prime 95 again. (watch your temps!)
Repeat all steps again
Once you reach temps of ~55C load DON'T INCREASE THE VOLTAGE ANYMORE, you can still increase the multi until it reaches the highest stable point but do not increase the voltage.
If you hit 1.5v before you get to those temps STOP INCREASING THE VOLTAGE again. Anything over 1.5v is considered dangerous due to the possibility of premature degradation.
Good luck, let us know how it goes!
Welcome to OCN!
EDIT: Also you can fill out your system Specs here. It will help us immensely when we try and help you!
Read... A few hours/days of reading and searching on this website will do you wonders.
1 - 4 of 4 Posts
