1 - 13 of 13 Posts
i need some help on how to overclockmy cpu and memory and im clueless as to how to do it... ive never overclocked anything and i dont know to much about overclocking, but u guys do so can u help me?
thanks
Please read through this guide first as it contains a wealth of information that will help you get started. Once you read through that, please post any questions you may have.
thanks im reading through it all and trying to understand it all but im still confused on some of it..
By all means post questions as you come up with them. Reading the guide is just an excellent starting point.
That's the ratio of the CPU frequency to the RAM frequency (very simplified). For Intel machines, it's generally best to run at 1:1, though sometimes a bit of performance can be gained by pushing the RAM faster than the CPU.
Discussion Starter #7
k thanks... im going to go attempt to overclock now and if i have problems ull see them here... thanks alot
Discussion Starter #8
in my bios under the cpu settings i saw a "fixed agp/pci frequency" setting and it was at 66/33. what should i do with that?
It is best not to change that one for two reasons. First it yields minimal to no performance results and second it can seriously screw up your computer ( destroy mobo, corrupt hard drive, etc.)
Discussion Starter #10
ok thanks alot, ill just leave that be and attempt my first overclocking!!! thanks again!
Discussion Starter #11
Sweet i just overclocked my cpu to 3.690ghz! and im running a stress test right now... so what do i do now, what was the bennefit of this overclocking? and how can i tell what speed my memory is running at? thanks alot guys!
The benefits of overclocking:
- Getting more performance from a system or as much performance as the one you can get from a more expensive system.
- The sense of satisfaction from doing it. It can become an addiction though !
The disadvantages of overclocking:
- Voids the warranty on the spot (although sometimes you can hide the fact that you overclocked your equipment) !
- Shortens the life of your overclocked components (you can lessen the impact overclocking has on your components by keeping your temperatures under control and being very careful to increase voltages in baby steps).
To determine the speed of your memory download this little program run it and go to the "Memory" tab where you will read "Frequency" under "Timings".
It'll also give you the FSB:RAM ratio right below it.
Keep a good eye on the temps.
1 - 13 of 13 Posts
