1 - 3 of 3 Posts
hello, i overclock my cpu from 3.0 to 3.48 , when i run 3dmark after 5-8 minutes its goes out and gove me a error that there was a problem with 3dmark and it had to go out, when i am not overclocking it work fine , but when i`m playing need for speed of football manager (with overclock) that really use the cpu it work geart! the coputer dont stuck or restart and the temp` dont go over 60...<br />
should i be worry?
what are your ram speeds and timings at at this point of you OC...?
if i understant you , my ram is 770 when i overclock, when i`m not overcloking is 667
1 - 3 of 3 Posts
