I can't get my comp to boot from the cd disk. What button do i have to press to get it to do this, If any? My Primary boot device is my floppy, then my WD.. I assume harddrive, Then my cd drive. Help?
Go into your bios and set the primary boot device to be the cd-rom.
I don't think there's a button to press unless it's a bootable cd and it explicitly says "Press any key to boot from CD".
Err.. you should be able to choose cdrom as primary boot device to make it boot from that.
Sometimes it askes you to 'press any button to boot from disk' when you've set your disk drive as primary boot device..
