I want to make this case
Since the recently released Titan is partially marketed as a low tdp great performance card for small form factor gamers,
I set out to see, if I were to purchase a Titan, what case could accompany it.
I really like the idea of Falcon Northwest Tiki (not shown), but
(1) the case is not for sale
(2) I wanted to go a step further and really showcase the Gtx Titan.
The GPU is almost always the most expensive component in a computer, and I think cases housing $1000 GPUs should do a better job really showing off what matters.
How would you guys suggest building a case like this?
I can imagine purchasing a custom made acrylic box for the top,
but I have no idea where to get and how to work with brushed aluminum or whatever else the body of the case will be made out of.
I have a bear saw and a drill, but anything heavy duty I will have to use the college's machine shop.
The inside: If you've seen the Tiki, AW X51, Bolt, or Revolt, the innerd arrangements are nothing new.
- Asus Deluxe ITX mobo
- 2x8GB ram
- Silverstone SFF 450w psu
- Scythe Shuriken ver 2 cpu cooler
- i5 2500k?? (not sure how well cooler will fare)
- SSD(s)
Although, I'm thinking a 60mm fan could be connected to the PSU so that air comes into the PSU, then goes up into the GPU casing.
Other SFF towers for reference:
- 2x8GB ram
- SSD(s)
