I want to tighten my timings to gain a little performance and general system performance.
I'm currently running my memory at 1666mhz, 1.701v at CAS9. (the sticks are rated for 1600mhz, 1.65v, cas9) Here is a BIOS screen. I'm trying to get them as low as possible:
I know the voltage maybe be a little excessive for a 66mhz overclock, but the ram appears to be picky at what settings it will run.
This is the kit i own:
http://www.pccasegear.com/index.php?...ducts_id=15518
Should i try running CAS8 first?
