help me to choice right CPU
584 Views 5 Replies 5 Participants Last post by  Aaron_Henderson
i wanna buy new PC with Processor AMD Phenom II X3 720 and mobo M3A76-CM , and cart HD 4850 can i unlock 4th core , or overclock my CPU ?
is it right choice to buy that CPU with that mobo ??
sorry for my bad english
1 - 6 of 6 Posts
I'd go with an MSI GD70 or a DFI 790FX. Yes that CPU is good.
You can definitely overclock, possibly to 4GHz+ with the right cooler. There's a chance you could unlock the fourth core, albeit low.
I'd go more for a mobo like this one: http://www.newegg.com/Product/Produc...82E16813138163
It has a 790GX chipset, which is a lot better than the 760G on the M3A76-CM. It also has DDR3 memory instead of DDR2.
Agreed, unless you are tempted to go Intel...
thanks guys
i'd buy this pc cost about 449 euro , is it worth with that price ?
Behuizing : HKC 7009NS
Voeding :HKC 550W ULTRA SILENT POWERSUPPLY
Processor :AMD Phenom II X3 720 Tripel Core (AM3, , 3 x 2.8 Ghz, boxed)
Moederbord : M3A76-CM
ATI RADEON HD4850 1024mb Gddr3,
Samsung 500GB S-ata2 7200RPM
KINGSTON 4GB DDR2 PC6400 800MHZ
DVD Brander : Samsung Dual Layer 22x
wierdo124 says you should go with a Celly D you said that right wierdo124? Oh yeah, I made it up
1 - 6 of 6 Posts
