1 - 20 of 20 Posts
Well i want to have good quality setup, i got the z2300, but i'm sure that good studio speakers and a home theater sub with a good receiver would rape the z2300..
So, i dont know if i would be better to buy a receiver first, then add speaker, then add a subwoofer or take a "bundle" and a receiver.. I'm not sure if i want a 2.1,5.1,7.2,9.2.. because im all about music... but in a stereo receiver you cannot plug a subwoofer?
I want to know what would be the best quality possible like 500$ the speakers, subwoofer 500-1000$ (i want a kick azz one) and a good receiver 700-1300$, buying one pieces at the time..
i was thinking buying this kit, is it a good one?
Amazon.com: Yamaha Pro Audio - HS10W: Musical Instruments Amazon.com: Yamaha Pro Audio - HS10W: Musical Instruments
or buying these
Amazon.com: Yamaha HS50M (Active) Pair 2-Way Monitors: Musical Instruments Amazon.com: Yamaha HS50M (Active) Pair 2-Way Monitors: Musical Instruments
and adding this sub
Amazon.com: Polk Audio PSW505 12-Inch Powered Subwoofer (Single, Black): Electronics Amazon.com: Polk Audio PSW505 12-Inch Powered Subwoofer (Single, Black): Electronics
I use the same equipment one model up actually in my house. works way better than most home audio stuff more power especially the 18s. Just think about it. the only disadvantage i have ever found is the size.
Originally Posted by darthspartan View Post
Thats more than the powered 18 i posted you would get more thump out of the 18 especially in the subsonic.
There's like basically no specs on that sub other than telling you it's 18" with 700RMS.
You have to be smarter than the web site SPECS you just go to the non powered model to get the specs. Your in La go see it at there store down there.
System Type: 18-inch Sub, bass-reflex
Frequency Response: 29 Hz - 265 Hz (-10DB)
35 Hz - 150 Hz (-3 dB)
Coverage Pattern: omni
Crossover: Low Pass
Crossover Frequency: 150 Hz
Power: Full Range 800w continuous /1600w program /3200w peak
Recommended Amplifier Power: 1200 - 2400w
Sensitivity (1w @ 1m): 98dB
Maximum SPL: 127dB
LF Driver: 18-inch woofer
Nominal Impedance Full Range: 8 ohms
Enclosure: 18mm Multi-Ply Hardwood
Suspension/Mounting: Top: 1-3/8-inch Pole Mount Cup
Finish: Black DuraTuff™
Transport: 2 Recessed Handles
Grill:Black Powder-Coated Steel
Connectors: Two NL-4 Neutrik Speakons, Two ¼ TS phone jacks
Dimensions: 600mm (23.5") high, 505mm (19.75") wide, 580mm (22.75") deep
Net Weight: 58 lbs
Discussion Starter #10
those receivers are nice. don't buy a klipsch sub.
svs, rythmik, hsu, epik, elemental designs, jl audio, and outlaw audio are who you should be looking at for subwoofers.
Quick post to just give you a general idea.
If you are going to piece together a system over time, start with the speakers. Buy the best speakers you can afford. This "investment" will be the single component (ok, multiple speakers) that you will own the longest. Add the sub afterwords, (surrounds, center; if you go multi-channel), and then finally your AVR/Receiver.
A good pair of "full range" speakers will overcome much of what you may miss from the initial lack of a subwoofer. A subwoofer, for most typical music listening, fills in the frequencies that a pair of low-end/small speakers are not capable of producing. A sub will also relieve much of the load from the stereo/multi-channel amp, as it is the low frequencies that place the most stress on the amp. Most music cantains few frequencies below 50Hz, as there are very few instruments that produce "sound" that low. In Home Theater, a sub is far more important than it is for music listening.
If I were spending your budget for music, I would be looking here:
Taking the money I'd be saving from from the $1000 sub budget, and investing the difference here. This speaker line has been around for quite some time, but the build and quality has not changed. It would also allow you to add additional speakers over time, to fill in a complete high quality HT surround system.
Front (stereo) speakers:
A current A current "bargain"
or (these if the bargain price goes away.)
These These
For the sub:
VTF-3-mk3, which is actually overkill in all but the largest rooms.
Discussion Starter #13
Why not starting with the receiver? After when you get the speaker you can at least test it, I like bass alot so this is one reason why i'm getting a good receiver for a killer subwoofer. Hip hop, metal, techno hard style, pop are the types of music that i lisen.
For the speakers i was thinking of buying klipsch ones, but i dont know if there are speakers that are good for "music" and other for "movie" in home theater speakers..
Speakers
Amazon.com: Klipsch Reference Series RF-82 - Left / right channel speaker - (EACH): Electronics Amazon.com: Klipsch Reference Series RF-82 - Left / right channel speaker - (EACH): Electronics
If i begin with only 2 speaker the receiver will do 250watts in stereo mode, its gonna be too much since the speakers are 130 watts, would it be dagerous for the speaker to be over amplified even if i'm never gonna put it at max?
Discussion Starter #14
Speakers
You typically end up spending more on speakers that any other piece of equipment, and as mentioned above, the speakers typically get used for a longer period of time. Receivers, HDTVs, electronics, come and go (get replaced) as new technologies emerge.
That's why the speakers should be first and foremost.
And no, you won't wreck speakers rated at 130w with an amp that puts out 250w. You will actually find that you will end up with "cleaner" sound, as you won't be driving the amp very hard, creating less distortion, and less potential for "clipping" in the audio signal.
Before you just buy Klipsch speakers, you should find a place to audition them. Many people don't like the horn loaded tweeters, (although you will find just as many people who do). The people who don't like the horn tweeters, find Klipsch speakers to be anything but neutral, IMHO, something I would look for in speakers at that price range.
I personally find the horns make the speakers sound harsh, creating a lack of subtlety. This coloration and brightness in the treble, to me, gives Klipsch speakers a hardness that can become very fatiguing.
Just my
. When spening this much money on speakers, it is best to take a listen before you buy.
Also, don't get too hung up on the wattage of the Amp in a sub-woofer. again listen to them before you buy... you don't need 1000w to fill a room with accurate bass. That is, unless you have a room in excess of say 2000 sq. feet.
I second this, pick subs from any of these company's. Quick question what's the size of the room?
Overclocked by Jesus
For the subwoofer, i want a quality one with 1000watts R.M.S and more, ive been looking at klipsch ones, but they are too weak and have a passive driver that is limited..
Why does it have to be 1000w rms? You said yourself talking about a 700w subwoofer for concert applications is ridiculous. 1000w is way overkill for something unless you have a huge room you plan on putting it in. Power does not equal low frequencies or quality. Personally I enjoy SVS or HSU for the price.
And as has been said before, don't even start with the receiver or subwoofer, put all your money in your Front channel speakers. A good front setup will make all the difference in the world even with a crappy receiver compared to an amazing receiver and crappy front speakers.
Discussion Starter #18
Yeah, but don't forget that i will upgrade from a logitech z-2300 that need to be EQ to death so they do not sound like transistor radio speaker..
Yeah, your probably right, it would be too much, i need one that can do very deep bass like below 30hz or 20hz if it's possible. For the speakers the Klipsch RF-82 i'm surprised that they can do 33hz.
Discussion Starter #19
Well lets compare that to the PB-12 NSD and Epik Empire:
Klipsch mfr freq response / weight / cost / type: 21-120Hz +/-3dB, 48 lbs, $999, 10" sealed
SVS mfr freq response / weight / cost / type: +/-3dB 18Hz-200hz anechoic, 74 lbs, $699, 12" ported
Epik mfr freq response / weight / cost / type: 20-300 Hz +/-3.5 dB anechoic, 140 lbs shipped, $799, dual opposed 15" sealed
There are tons of other fine options available from other manufacturers as well.
1 - 20 of 20 Posts
