hey guys
my goal is always to reach to 5.0ghz and i am always failing...i am getting 0x0000124 bsod error after 2 hours of prime test here are my current settings of my bios:
-Ai Overclock Tuner: Manual
-BCLK/PEG Frequency: 100.0
-Turbo Ratio: By All Cores (Can Adjust in OS)
-By All Cores (Can Adjust in OS): 50
-Internal PLL Overvoltage: Enabled
-Memory Frequency: DDR3-1600MHz
-Memory bandwidth booster: Disabled
-iGPU Max. frequency:auto
-EPU Power Saving Mode: Disabled
-DRAM Timing Control: 8-8-8-24-2.
-CPU Power Management:
--CPU Ratio: 50
--Enhanced Intel SpeedStep Technology: Enabled
--Turbo Mode: Enabled
-Vcore pwm mode: extreme
vcore mos volt control: auto
-Vcore Load-line Calibration: Auto
-Vcore switching frequency: Auto
-Vcore Phase Control:auto
-Vcore over current protection: 100
-iGPU Load-line Calibration: Auto
-iGPU Current capability:100
-CPU Voltage: Manual Mode
-CPU Manual Voltage: 1.440V
Dram Voltage: 1.5
-Dram data ref voltage on cha: Auto
-Dram ctrl ref voltage on cha: Auto
-Dram data ref voltage on chb: Auto
-Dram ctrl ref voltage on chb: Auto
-VCCSA Voltage: Auto
-CPU PLL Voltage: Auto
-Pch voltage: Auto
-Pch rcc voltae: Auto
-Cpu spread spectrum-disabled
CPU Configuration:
-Intel Adaptive Thermal Monitor: Enabled
-Hyper-threading: Enabled
-Active Processor Cores: All
-Limit CPUID Maximum: Disabled
-Execute Disable Bit: Enabled
-Intel Virtualization Technology: Disabled
-CPU C1E: Disabled
-CPU C3 Report: Disabled
-CPU C6 Report: Disabled
-Package c state limit: No limit.
Can anyone help me with which things i gotta change?
thanks!
--CPU Ratio: 50
Dram Voltage: 1.5
-Pch voltage: Auto
CPU Configuration:
-CPU C1E: Disabled
thanks!
