1 - 2 of 2 Posts
Put together new system with NZXT Kraken X42 AIO, Asus z370 itx, it-8600k.
When assembled out of case to test, everything run fine, idle was 35c, aio and fans connected to cpu_fan.
Put everything into case, aio is making small grinding noise, idle shoots to 80c right after boot.
Changed aio pump to aio_pump socket so it runs 100% and fans to cpu_fan and idle temps are 50c.
Really lost what happened here.
Sent from my LG-H873 using Tapatalk
It sounds like the pump died, probably from a slug of air.
1 - 2 of 2 Posts
