Help me understand 1920 x 1080 monitors...
1117 Views 12 Replies 7 Participants Last post by  Mootsfox
I'm looking at getting some new monitors for a dual set-up. And I'm finding a lot of the new ones on the market now are 1920 x 1080 resolution. My question is, will the driver that comes with these monitors add that resolution to my display options so everything is proportional? Or will my screen get stretched annoyingly?
1 - 13 of 13 Posts
It might but seeing that you have a nvidia card you can make custom resolutions in the nvidia control panel if it dose not work. Hope this helps
Hey thanks Maddog7771, I'll have to check that option out.
I'm almost positive a 9500gt can handle 2 displays at 1920x1080, but I've never owned one. If by stretched annoyingly you mean your desktop image, that may happen if you have the monitors at 2 different resolutions.
If your monitor uses a digital interface (DVI or HDMI) then the resolution options should automatically show up. You'll be fine.
No problem. But to make a custom resolution just open you control panel under advance and their should be a option under display that says "Manage Custom Resolutions" This helped me get my tv to work with my computer lol
It's not a question of drivers. It depends on the original size of what you are displaying.
1920x1080 is a 1.7777 ratio (width divided by height). If the original has a different width to height ratio, then it has to be stretched to fill the screen.
it should work by making a custom res. and the 9500 is a decent card. For not gaming there is no reason to get better. So you will be fine.
That's what I mean... kinda. I think? I don't want a square to end up being a rectangle as it stretches to fill this new resolution screen. That's why I thought maybe a driver would let the card know that it's 1920 x 1080 resolution and add that to the pulldown option in the display menu.
But from the sounds of it, I should be okay without the stretching. Now just gotta decide on what monitors to get.
Thai: You say monitor(s)? Are you planning on buying 2 new ones and using just those? Or buying 1 new one and using an older one you already own? Or 2 different sized new ones?
I'd like to buy 2 new ones and set them up as duals. 24"+ each.
I'd use Ultramon to set them up, so it'd be 1920 x 1080 per monitor.
Here's what 1280x1024 (1.25:1 ratio) and 1280x720 (1.77:1 ratio) look like onmy dusl monitor setup.
"Drivers" won't make the right screen look "not stretched".
1920x1080 is an option, it just may not show up with your current monitor. You'll have zero problems with it
1920x1080 is 16:9, 1080p same as TVs. It's appealing for that reason, and it's a much cheaper panel to cut during manufacturing, so it's appealing to LCD makers; that means lower cost per pixel.
1 - 13 of 13 Posts
