Alright, so I plan to upgrade my rig (see sig) with a Thermaltake Armor ATX case, going to yank out the back fan and put in a 120mm LED fan.
My questions to you guys:
1) Which 120mm LED Fan is: Durable, quiet and moves decent Amount of Air?
2) Is there something bad about this case that I should know of?
3) I am probably going to buy the PC P & C 750W PSU, it is 7inches deep, would it create problems with the Tt Tower?
4) I plan to buy a Fan controller that fits in a bay, I noticed that some only work with 3 pins outlet, but the CPU fan is a 4-pin and I would like to control that. Which one should I buy so that I can play around with the CPU fan speed?
+ rep for useful infos provided
Thanks
Thanks
