1 - 4 of 4 Posts
i just reformated and now it shows 127gb whats going on how do i get back my 250gb please help
Overclocking since 1998
You need to enable 48-bit addressing:<br><a href="http://support.microsoft.com/default.aspx?scid=kb;en-us;303013" target="_blank">http://support.microsoft.com/default...b;en-us;303013</a><br><br>
Some older motherboards don't support ATA drives above 127GB. Also you need to have WinXP SP1a or higher, but you sig says you have SP2.<br><br>
So probably just windows didn't install correctly. Look at the link above to fix it.<br><br>
You can use the search feature for "127GB". It is a very common problem.
Did you read my reply in your other post on this matter?
Discussion Starter #4
thanx guys for helpin me fix the problem
1 - 4 of 4 Posts
