1 - 8 of 8 Posts
My friend wants to cool his 2500k plus 2x6950s on a water cooling loop.
He has the RS240 rasa kit + a 120mm black ice radiator.
Will he need another radiator?
as in 240mm+240mm+120 to cool the cards and CPU?
Hi
I had a XSPC kit with a 2500K and 2 GTX 460's and that about the limite of the pump tryed to add a RX240 and flow went down to nearly 0.
Plus i am running RX Rad's
What case are you using and could he fit a 480/ / 360 RX RAD ?
If you had the two 240's and he didn't overclock then he should be fine but ideally he would have a 360 and a 240 in the loop for an OC and the two gpu's. He needs a 240 at least for the cpu OC and a 360 for the two gpu's.
Discussion Starter · #6 ·
Dang. didnt realize how much he needed to cool his system.
well. He can get a total of 240 + 120 + 240 but the only issue is. Will the RASA H2O 750 pump/reservoir handle that much ? People said they were weak.
Not New to Overclock.net
My XSPC 450 lph pump handles EX240, Black Ice 120, Black Ice 92, EK Supreme CPU block, and an EK 5970 block without issue
The pump will be fine, I'm running an RX360 rad on a XSPC Raystorm and two Heatkiller Full Cover GPU Blocks and the flow I think is fine. I have nothing in the loop to show me anything regarding flow, however the water line in the Res is quite turbulent so im guess flow is good. I also have good temps which i guess could indicate im not getting poor flow.
As for the rads he needs, I would go with EX240 not RS240 and get a EX120. Thats if he can't fit a say a RX360 in anywhere, unless he doesn't care whether things are internal or external. You don't need boat loads of rads.
1 - 8 of 8 Posts
