Help! my Loops are making squishy sounds
327 2
GPU loop-
I don't see any bubbles in my tubes but there are tiny little bubbles
on the wall of my res
CPU loop-
There seems to be a good amount of bubbles in my res.
But it appears as they are caused by the flow into the res?
Do I run the loops with the caps off the res and put the caps back on while there is flow?
1 - 3 of 3 Posts
Hi.
Yes. allowing the loop to run overnight with the reservoir cap or T-line cap loose will eliminate all those tiny bubble.
Add-on: I have allowed loops to do the final bleeding while the system has power without any issues. Once the loop is bled I would tighten the cap prior to shutting the system down.
[edit] You could also press on the tubes to break the cohesion that is holding those tiny buggers to the tube-walls.
Thanks,
The Micro Res is cleared up. Now for the DD 5 1/4 bay.
1 - 3 of 3 Posts
