I saw that you wanted to use prices from Bell Systems...so you are opposed to ordering from newegg?
Originally Posted by pvp309rcp ![]() For one...I think this is in the wrong section. Don't know if any mods are here but this should be moved to the Intel General Section. First and foremost...you have two monitors...we should know whether you are deciding to dual screen or if you plan on using just one as well as how big it is in terms of maximum resolution. This is how we decide on what necessary computer hardware/components/parts you need. If you are wanting to be able to play MW2 and Crysis then it shouldn't take much depending on your resolution. However, if you are looking to get maximum detail then that's a whole different story. It seems like you're wanting to go the Intel route. You have three choices from lowest to highest. Socket 775, 1156, and 1366. I do not recommend 775 since that technology is aging to the point where you might have to move on to 1156 or 1366 anyway for your next upgrade. If you're not wanting to spend the highest possible then I recommend the 1156 route. But since you're interested in the Core i7 920 or 950 I guess it might be the 1366 route. Both the Corsair Obsidian 800D and the new revision NZXT Tempest are great choices so it really comes down to features and looks. I'm going to have to be biased with this choice so if your budget permits then I think the Obsidian is the best case to get since it looks easy to work with in terms of cable management (plenty of holes with no hard modding required). It also features hot-swappable drives, extra expansion for GPU exhaust, very spacious (lots of room to work with), and is ready for a 3x 120mm radiator at the top exhaust when you go water cooling. I don't think you should get the Corsair H50 if you plan on water cooling your PC. It's usually recommended for those want a quiet case or an additional alternative to high-end air cooling. I for one have no idea when it comes to water cooling but you should check out the Water Cooling Essentials thread for guides and help. Also put into consideration that if you water cool...that you should get high quality parts which can be pretty expensive. So your choice maybe to buy the best hardware you can with the $2,000 budget and then save up for water cooling. All your parts may be based on what others think since I don't know what brands you like or dislike and I'm biased when it comes to them. Me = Intel/Nvidia and Evga when it comes to service and warranty. |
