Ok after running prime95 100% load for 2 hours the Max I got to was 67c has any one done lower then this on a i7 950 ?
I mean is this ok for a i7 950 overclocked to 3.8GHz can I overclock any further ? The Cpu cooler is a Noctua NH-D14 with 2 fans 120mm and 140mm My case is Coolermaster 922 with the follwing case fans
Intake front 200mm
Intake side 200mm
intake bottom 140mm
outtake top 200mm
outtake back 120mm
Intake front 200mm
Intake side 200mm
intake bottom 140mm
outtake top 200mm
outtake back 120mm
