1 - 13 of 13 Posts
Like the title says, I need one! Need to transport a sound card via checked luggage. Any ideas on what I can use?!
cotton towel. Wrap it up.
Originally Posted by DiagnosisDirt
Small Box And Unsalted Popcorn , But Put The Vidcard In A Baggie, Devoid Of Air.
No way, pop corn? Thats awesome.
Or just use a small box that fits the card and use a towel or something to put in the box to keep it from knocking around. I actually just use like a white T shirt or something. The soundcard won't get messed up with static unless it's cold and you rub your feed on a shaggy carpet. But if your still scared, just touch a piece of metal before you open the box. PC cards can take alot of abuse.
Originally Posted by Solarcaine View Post
I hink popcorn would be bad in that matter. I wouldn't doubt you'd get all sorts of the crap stuck to your card.
i take it you didnt read the part where he said to put the card into a baggie
yeah there is a lot of lead in soundcards. They wont let you onboard with that cuz they will think its a bomb. With laptops, tehy make you boot them up to prove it, but you cant test a soundcard...
I'll be watching the evening new to see if he made it.
1 - 13 of 13 Posts
