For awhile i have strictly been overclocking my GPU. I have not yet had the courage to take a step into overclocking my CPU yet. (primarily cause i dont have a job so if i mess up my processor im screwed). So at stock my CPU is 3.2 Ghz, i wanna try to go too 3.4 Ghz with complete stability. all my listed parts for my "Blue Beast" build are up-to-date. Using Core-temp it shows that idle my CPU temp is 42C. Havent gotten to check under load yet. Also my Phenom II x4 955 IS Black Edition.
So really im wondering where should i start? Also any ideas for tools i should use?
