1 - 20 of 22 Posts
could someone give me directions on how to run gpus on ubuntu 9.10 32 bit?
i tried to follow error 10's guide and everything worked up until step 3.
also i think i'm unable to run smp so running 2 single cores now.
for some reason i seem to be unable to run 9.04 both 32 and 64 and 9.10 64 on my usb bootable
and i'm quite new to ubuntu so detailed instructions would be great. thanks
first off, go to 64 bit.
secondly, report back here once you did
Discussion Starter · #8 ·
i'll give it a try with 64 bit one more time tonight and report back. i've tried so many times with pen drive and livelinux creator but it was futile.
Discussion Starter · #12 ·
alright. thanks for the help so far guys. i think i've managed to install smp though it's not using both cores at 100.
i tried to use mentioned guide to install gpu but i've got problem saying something about kernal. could anyone shine more light on this matter?
oh and now it's on 64 bit
Okay, now I am all ears.
Can you elaborate on the 'kernel' problem / error?
Also, did you specify the "-smp 2" flag to make sure you are getting SMP WU (designed for multi-core CPU, and will be using it at near 100%), and not older UniProc (Classic) WU (which are designed for the PIII, and it's lackeys).
Discussion Starter · #14 ·
in install nvidia cuda drivers and toolkit
step 1,2,3,4 works fine. but for 5 i can't put the code in terminal unless i close the thing i opened in step 1.
so let's say i closed it and put in sudo sh ~/Desktop/NVIDIA.run --no-x-check.
step 6 and 7 comes out so i select accept and no respectively.
then it says no precompiled kernel interface was found to match your kernel and they'll compile the new one.
then error message says if using linux 2.4 kernel make sure kernel sources match your kernel or headers installed on the system. if 2.6 same as above. etc.
let me get screeny soon
oh and the drives i downloaded are
http://www.nvidia.com/object/thankyo...77.73-pkg2.run
and
http://www.nvidia.com/object/thankyo...ubuntu8.04.run
Discussion Starter · #19 ·
i'm going back to windows. this is taking wayy too long for me to set up. but it was a good experience but right now i don't really have the time to set up and study linux during school. reps all around
1 - 20 of 22 Posts
