1 - 7 of 7 Posts
Hi
i did some overclocking last night with my 7940x on a Strix x299 gaming e
this was my OC settings:
adaptive volt 1.229v with negativ offset: -0.32v
loadline call lvl 2
OC by each core
2 cores: 4,6ghz
12 : 4,5ghz
all the volt in the "each core menu on auto"
ran prime 95, after 6 min the pc turned off (no bluescreen)
temps was under 90c before shutdown
now the pc turns on for 2 sec and back off, HELP plz
Did you try unplugging the computer for 60 secs and then replugging and testing? If that doesn't work maybe a BIOS reset with PC power cord unplugged is in order.
The power cord has been out all night, no changes
I had 7900X and MSI X299 Tomahawk AC board. I removed it to clean with blower on lowest setting. But after putting it all back, motherboard shows the dreaded 00 error code with CPU debug LED glowing on it.
Tried the PSU on another system and it booted perfectly and sleep worked on it too. So ruling out PSU problem. My fans turn but CPU not getting any power.
To Op, rule out PSU fault by testing it out separately first.
Rig Advisor
Hi
loadline call lvl 2
OC by each core
2 cores: 4,6ghz
12 : 4,5ghz
Reset CMOS. Take battery out for 15 minutes.
Discussion Starter #6
what is the chance that i fry'd somthing when i let the volt be auto?
Discussion Starter #7
leaving the bios battery out while eating dinner (30m+) did it!  thanks guys!
im now wondering what happend :
i used adaptive mode with negative offset
(1.229turbo vcore  - 0.31v offset)
and in the specific core menu i had auto on all the volts and 45-46 on the cores
i ran prime 95 with negative avx 2  and 3  when it crashed
any1 know where i fakked up? thanks again!
1 - 7 of 7 Posts
