1 - 2 of 2 Posts
Hi all,
I have 2x6800LE's PCI-e running on an Asus A8n-SLI MB. I've flipped the card on the MB to enable dual mode, installed the Nvidia Force drivers and the software kindly let me know the system was set for SLI. My benchmark showed the 94% increase. So all looks good so far...
I started to OC the card(s) using coolbits2. The GUI is easy and the system easily took a nice OC, from 350/400 to 424/799 without any problems. Except... I can only select the first GPU. When using coolbits with a SLI system, will it OC both cards at the same time? If not, how would I go about bringing the second LE up to par? I have not been able to do so in coolbits.
Thanx a bunch
You are overclocking both your cards simultaneously when changing the clock settings.
1 - 2 of 2 Posts
