Help on buying watercooling stuff
661 Views 15 Replies 6 Participants Last post by  Chunky_Chimp
Can you guys help me to choose the right water cooling parts for me?
Here's what I have so far:
Pump = Danger Den D5 12V Water Pump
Radiator = Swiftech Extreme Duty Triple 120mm Stackable Radiator with 1/4" BSPP hubs
CPU Block = Swiftech Apogee XT Waterblock for Intel socket 1366 (Core i7) and 1156 (Core i5)
Im planning to cool my i7 920 @ 4.2, 2x 285 GTX and if possible my x58 760 mobo... WOuld that be enough cooling for all, atleast for the cpu and the 2 VGA?
Also im not sure which tubing will fit in there and which fitting should i use
any help would be appreciated
thanks!
oh and if you can suggest better parts than those above please feel free
1 - 16 of 16 Posts
Nice parts so far. For tubing, that's all on personal preference; either 3/8" or 1/2" is perfectly fine, just choose any OD (outer diameter) and you're set; as for the brand, go for Masterkleer (avoid ClearFlex, it tends to cloud up) if you're on a budget, or Tygon if you have lots of tight bends. After that, pick fittings/barbs that match the tubing size (and make sure they're G1/4"; I recommend Bitspower compression fittings), and then fans for the radiator (see here for recommendations). If you want a reservoir, the Swiftech MicroRES is an excellent option that will fit just about anywhere. Hope this all helps.
so for the tubing its either a 3/8" or 1/2" OD? Will it fit those parts? Dont i need to consider ID as well?
thanks for the input BTW!
+1 rep
+1 rep
No, you can also get 7/16" tubing. 7/16" tubing is a favorite around here when paired with 1/2" barbs because it gives a snugger fit on the barb itself and thus is more likely to prevent leaks.
+1 rep
Well by 3/8" or 1/2" I'd meant ID (though there's not just that, you can use 7/16", too, if you want, like AKIMbO said above), and you choose whatever OD you think works better; just make sure the fittings/barbs you get match the tubing dimensions or it won't work.
You will also want clamps if you are using standard fittings. I have used herbie clamps, worm drive clamps, and zip ties. Personally, I recommend the worm drive clams, as they grip the tubing very well and you can tighten them down quite a lot.
Alternatively, you can use compression fittings. Keep in mind that with those, you need to match both the ID and OD, not just the ID.
Also, for the D5, I think you should stay away from 3/8 ID tubing.
you don't need a stackable rad unless you are going to get 2. I advise the normal swiftech triple one.
+1 to this idea. It's exceptionally hard to get 7/16" tubing over a D5's barbs without first heating up the tubing in some hot water...so i can't imagine trying to get 3/8" tubing over it.
No reason to to w/c you chipset.
standard set up
1/2 inch barbs for everything
mcp655 pump or mcp355
http://www.jab-tech.com/Swiftech-MCP...r-pr-3803.html
65.00
tubing
http://www.petrastechshop.com/7id5odmagepu.html
.59 a ft
rad(x2) feser performance but not the price
http://www.jab-tech.com/XSPC-RX360-T...r-pr-4384.html
94.00
or RS360 like 45.00
fans
http://www.jab-tech.com/YATE-LOON-12...d-pr-3771.html
3.70
or
panaflos better choice
120x120x38mm
fan controller
http://www.xpcgear.com/rheobusext.html
28.99
or
http://www.newegg.com/Product/Produc...82E16811998808
15.00
reservoirs or tline
http://www.crazypc.com/products/wate...eservoirs.html
20-xxx
cpu
you have a good block picked out
gpu
http://www.heatsinkfactory.com/ek-nv...---nickel.html
or
http://www.crazypc.com/products/PX9365GTX285.html
Thermal paste : OCZ Freeze or IC Diamond
Coolant: distilled water and 2 drops of pt nuke
one is for just distilled other is used with U/v dye
http://search.store.yahoo.net/cgi-bi...uery=pt%20nuke
Loop should go
res-pump-rad-cpu-rad-gpu-gpu-res
Also, I would advise that you get a reservoir. While you can get away with a T fitting to fill and empty your loop, a res will make this process much faster and easier. Swiftech's micro-res is a great size, and you get tons of ways to mount it.
This is true. I was actually thinking more about the amount of restriction 3/8 ID would have for a D5. A DDC would be better suited for that size tubing (as it has more head pressure)
Originally Posted by Juggalo23451 View Post
you will need to get another rad for the gpus as well for best temps
What the -- no you don't...
a 360-size rad handles an OC'd CPU and 2 GPUs perfectly fine.
Not so much with the RS360 or Swiftech rads, really. Anything with decent pressure running 600-1200RPM is more than adequate.
I agree. I have seen a huge tendency to over-rad, and its often just not necessary.
depending on how high he wants to OC to for the i7 as well as the gpus.
What would be the max OC for a i7 and if you want to o/c the gpus as well if going with one 360 rad?
How should I know? It depends on the individual chips. You (and some others) seem to have a habit of SEVERELY overestimating the cooling requirements of these parts.
1 - 16 of 16 Posts
