1 - 5 of 5 Posts
As my title states I am new to overclocking, but would like to get the performance gain, minor or major. I would love to read some guides, but most overclocking guides seem to be for CPU's. I can't OC my CPU, it's a locked Sandy Bridge, but would love to learn on my 460. Could you either point me at some guides to read, or type out what I should do?
I've downloaded EVGA Precision, Nvidia Inspector, and EVGA OC scanner. I was dumb and did some OC'ing without much reading/previous research, but don't think I've done any damage. I raised my Core Clock, and Shader clock 10mhz at a time-they're linked, than ran the OC scanner for around a half hour. Than I would do it again. This was using nVidia inspector. When it failed the test, I bumped up the voltage one level. Currently I'm sitting at a 865mhz core clock, 1730 shader, and 2000 memory at 1.000v. Is this safe to run it slightly higher than normal? I have started folding so my computer is either gaming or folding, and I would like this to last a while.
Also, what would be the best driver to run BF3 with? Currently I'm running 290.53, but didn't know if I should change that.
Thanks for your time, and help!
Programmer
To answer your question with the drivers, use 290.53 Beta. Make sure you follow my Nvidia uninstall guide to remove your current drivers.
Reactions: raptorxrx
Thanks, I am running that, but do need to check if I deleted old drivers!. Now on to the OC'ing part!
Programmer
No if your running the latest then you should be alright.
as for clocking, all i can suggest is up the core by 10 each time and test. It might be a waste of hot air for an extra 1-2fps in very demanding areas.
If I were just gaming I might not want to, but my overclock has sped up my Folding a fair amount actually. Anyone else?
1 - 5 of 5 Posts
