Originally Posted by AMD+nVidia
I do believe you're gonna need a better PSU. You might be ok, but just to be safe I'd say you should upgrade
His rig wouldn't pull anywhere close to 500W under full load.
Each HD5770 takes <100W and <180W when CrossFired together.
OP: You will need a new motherboard, since P35 can only do x16/x4 CrossFire, this will bottleneck pretty bad. Something like a Gigabyte UD3P-EP45 would be my choice of a replacement board, it's an amazing overclocker, and comes at a great pricepoint.
If you wanted a power supply upgrade, I recommend either the Corsair TX650 or the Antec TruePower New 650W. Both are more than enough, and would allow for some upgrade headroom for a few years to come.
