1 - 7 of 7 Posts
Im going to need to be getting a wireless adapter (PCI) for a neighbors computer soon. Im thinking about <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16839121008" target="_blank">this</a> card but Im not sure. Got any comments on it, or suggestions on another one?
Linksys wireless adapters are among the best; can't say the same for their routers<img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" /> .
You should really think about a more powerful card if you need range. <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16833124178" target="_blank">This one</a> will pick up access points from blocks away if its in your price range. I have one.<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
i gotta linksys 54MB/s PCI card w/ something called "SpeedBooster"? quit easy instructions, and works perfect!
Discussion Starter #6
thanks, no not in the price range <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
The one you posted will do jsut fine as long as the router is not more than 3 floors away.
1 - 7 of 7 Posts
