Ive just tried to overclkock my PC and now it wont turn on. Ive tried dumping the BIOS settings using the jumper on my mobo but that didnt work.
I just tried to set the FSB to 260 on a 1:1 ratio, it booted ok at 250 so i thought id try 260, then as soon as i switch on the computer i get long continuos beeps which i have experienced before when trying to decrease the latencies on my ram so i figure ive just hit the ceiling for my RAM. In the past clearing the BIOS has fixed this but this time the damn thing wont switch on. I had my VCORE voltage set to 1.53 but the actual was 1.5 on the BIOS readout and my RAM at 2.8. I know this probably means either a damaged MOBO or CPU, I've tried removing the ram sticks individually and get the same results, ive tested also the PSU and i know that that isnt the problem. If anyone can help then it would be most appreciated!
