1 - 4 of 4 Posts
What would i need to do to overclock this cpu? I have the ASUS A8R-MVP (Crossfire Xpress 200) Motherboard. I would also like to know how the dual core benefits you. Thank you so much.
Here is an Asus How to.. not on your MB but a good referance.
http://www.overclock.net/faqs/38169-...roduction.html
I'm not firmiliar with your MB so I'm of little value in that respect
OH... BTW, The "USER CP" top of page will take you to you "Profile'' so please add in your system... it will help others help you.
Try this out first:
DDR333 RAM divider (dunno what kind of RAM you have)
240FSB
10x multiplier
4xHTT multiplier
1.45v on the CPU
+0.1v on the chipset volts
That should net you an easy 2.4Ghz. I bet you could drop the CPU voltage to 1.4v also for cooler temps and it will still be daily use stable.
1 - 4 of 4 Posts
