Hello,
I'm kinda new to overclocking, I have managed to get up to 3.8Ghz and being stable with it. I'm eager to learn more and with your help I hope to be able to get to 4.2Ghz. I have been told that to achive 4.2Ghz I will have to overclock my memory, but in doing so may blow my memory controller over time. So should I keep an eye on my memory controller temperature, what could I use to check the temperature?
My Spec is:
Asus P5Q3 Deluxe Wifi-AP @n
E8500 EO stepping 3.16GHz @ 3.80GHz
Corsair Twin3X2048-1333C9DHX - 9-9-9-24 @ 1334Mhz
I'm using a thermalright true copper heatsink with 2 120mm fans, In a push and pull configuration, well the heatsink is close to the intake fan so it has cold air pushed on it, so its like a push pull configuration. Current Temps are 39c idle on both cores, and about 47 - 50c on load.
The bios settings are as follows
Ai Overclocking Tuner = Manual
CPU Ratio Setting = 9.5
FSB Frequency = 400
PCIE Frequency = 100
FSB Strap to North Bridge = Auto
DRAM Frequency = DDR3-1334MHz
Dram CLK Skew on Channel A1 = Auto
Dram CLK Skew on Channel A2 = Auto
Dram CLK Skew on Channel B1 = Auto
Dram CLK Skew on Channel B2 = Auto
Dram TIming Control = Manual
Primary Information
CAS# Latency = 9 DRAM Clocks
DRAM RAS# to CAS #Delay = 9 DRAM Clocks
DRAM RAS# Precharge = 9 DRAM Clocks
DRAM RAS# Activate to Precharge = 24 DRAM Clocks
RAS# to RAS# Delay = Auto
Row Refresh Cycle Time = 60 DRAM Clocks
Write Recovery Time = Auto
Read to Precharge Time = Auto
Secondary Information
Are all set to = Auto
Third Information
WRITE to PRE delay = Auto
READ to PRE delay = Auto
PRE to PRE delay = Auto
ALL PRE to ACT delay = Auto
ALL PRE to RED Delay = Auto
DRAM Static Read Control = Disabled
DRAM Dynamic Write Control = Disabled
DRAM Read Training = Disabled
DRAM Write Training = Disabled
MEM. OC Charger = Enabled
Ai Clock Twister= Auto
Ai Transaction Booster= Auto
Voltages
CPU Voltage = 1.22500V
CPU GTL Voltage Reference(0/2) = Auto
CPU GTL Voltage Reference(1/3) = Auto
CPU PLL Voltage = Auto
FSB Termination Voltage = Auto
DRAM Voltage = 1.80v
NB Voltage = 1.30v
NB GTL Reference = Auto
SB Voltage = Auto
PCIE SATA Voltage = Auto
Load-Line Calibration = Auto
CPU Spread Spectrum = Disabled
PCIE Spread Spectrum = Disabled
CPU Clock Skew = Auto
NB Clock Skew = Auto
CPU Margin Enhancement = Optimized
Any help and advice is appericated
