1 - 5 of 5 Posts
i am not familiar with OCing AMD CPUs but i can see that your multiplier is x13 and if you want your CPU to run at 3.0GHz you need to set your FSB to ~230MHz. afterwards, check your temps to make sure that they are not too high under load
you might want to search the amd forums for athlon 64 fx for more info
Hi there. shouldent be a proble increasing cpu speed to 3Ghz.
but u might need to take some steps to make it work. first of all u need to give us more infomation about your setup, like what cooling u are on and a picture of main menu in your bios would be helpfull.
1 - 5 of 5 Posts
