help overclocking Q9550 please...
763 Views 18 Replies 6 Participants Last post by  freddy-b
hi there
I Just switched my Q9400 with a Q9550 And I need some help to get me satrted... b4 i had My Q9400 at 3.6Ghz.
and now with the Q9550 it seems Kinda harder to overclock it with my P5Q deluxe..!
Could u help me...?
thanks in advance,
freddy b
1 - 19 of 19 Posts
Are all your ram timmings set? voltage set? Start by dropping your ram freq down a notch and start pushing the cpu freq up 5/10mhz at a time untill it bsod or won't boot then bump up the vcore one notch and boot. Test with prime95 or occt and keep an eye on those temps. Throw up some screenies of cpu-z main, memory, spd.
ok
I gotta step out for an hour be back to check ya.
Originally Posted by freddy-b
hi there
Could u help me...?
thanks in advance,
freddy b
Q9550 is very easy to overclock with P5Q Deluxe.
Try my settings for 4ghz OC
CPU multi: 8.5
FSB: 471
CPU Vcore: 1.2875v
CPU GTL ref (0/2): .67
CPU GTL ref (1/3): .69
CPU PLL: 1.56
FS Termination: 1.26
DRAM volt: depends on your RAM
NB volt: 1.24
NB GTL ref: .65
SB volt: 1.10
PCIE volt: 1.50
LLC: enabled
CPU spectrum: disabled
PCIE spectrum: disabled
CPU multi: 8.5
FSB: 471
CPU Vcore: 1.2875v
CPU PLL: 1.56
NB volt: 1.24
NB GTL ref: .65
SB volt: 1.10
PCIE volt: 1.50
LLC: enabled
i still cant get it stable,
windows boots up and then when i am in the desktop it Freezes...any help..?
Originally Posted by ArchCorsair
What kind of fan do you have on your TRUE? Maybe its getting too hot.
temps were around 23 deegrees idle stock. i use Arctic silver 5...
i dont think it was over heating...
what do u think...?
Can you post all your settings in bios?
yeh sure gimmie a minute..
here...
ratio: auto
FSB Freq : 471
PCI Freq: 100
FSB strap to NB: 333
Dram Freq: 943
Dram CLK Skew ( all ): auto
Dram tatic read control:disabled
Dram read triming: disabled
mem OC charger : disabled
Ai clock twister: auto
ai Transaction booster: auto
CPU Voltage: 1.33135
CPU GLT Referance 0/2: 0.675x
CPU GLT referance 0/3: 0.690
CPU PLL Voltage: 1.56
VTT: 1.30
Dram: 2.2 (auto)
NB: 1.30
NB GLT referance 0.650
Sb voltage: 1.10 auto
LLC: enabled
Cpu Spread spectrum: disabled
PCI E Spread spectrum: disabled
Cpu clock skew :auto
NB Clock Skew: auto
Cpu Margin Enhancnmet: optimized
here are all My Settings...
Sorry about the delay, I had to step out to buy some medicine; I'm sick
Well to start things off, seems your Vcore is a bit high (what is your goal speed?)
For increased stability you may want to look over this guide to set your GTL per lane:
http://www.overclock.net/intel-mothe...ml#post3167191
Other than that, I'm not sure about your mobo so I can't really say what the voltages should be on the NB & SB.
Hope this helps
Hope this helps
my Goal Speed is 4.0Ghz
Well, try to either increase the CPU voltage or lower the FSB. You'll have to overclock in small steps, each CPU OC'es different. And what programs do you use for stress testing?
Hi
it could be your nb voltage try to bump it up, i think 1.3 volts is default , high clock speed with 4 gb of ram , nb will need a maybee 1.4v .
freezing in windows could be your memory.
hope this helps
i use intel burn test and Super pi and prime95
Originally Posted by stevezer View Post
Hi
hope this helps
ok, ill try that out, what Vcore should i put and vtt...? please give me a range..
i tryed putting the vcore at 1.28 and the Vtt at 1.30 and the NB at 1.26 and it didnt work it freezed during boot up...
1 - 19 of 19 Posts
