Help, PC won't boot
629 Views 19 Replies 10 Participants Last post by  eagles051387
Hey guys I need some help!!!
I'll start from the top, I've been running my pc overclocked for months 2.5GHz temps never rising much above 40 load. Last night I turned my PC off and it stayed @ the log off screen for ages, I just help in the power button to turn it off in the end. Didn't think anything of it, woke up this morning tried turning it back on and it didn't post, the DVD drive seems to start up, all the lights come on but it doesn't do the usual beeps. Have I messed my CPU or could it be my graphics card or my mobo? Can anyone help?
1 - 20 of 20 Posts
how many times does it beep if two it might be your ram...
Sounds like a mobo problem. I would have said PSU died, but it powers up, so it can't be that. Did it go through a storm or anything? I recently fixed a computer whos mobo blew after a storm (luckily nothign else went with it).
Right I've tried a CMOS reset, taking each stick of ram out, taking out the graphics card and reseating it. It doesn't make any beeps, the only thing that seems to happen is the DVD drive starts up and the lights come on the mobo. Theres a PC shop open till 6pm today so if I can find the problem I can go buy what I need.
Do you remember your boot order in bios prior to the calamity?
Sounds like a bad hard drive.
Sounds like a dead motherboard to me. If you get no beeps at all thats not a good sign I would RMA it .
hmm, non of the components smell funny? smell them all closely
Nothing smells funny, I have a spare old 939 socket mobo, I might try plugging everything into that and see what I get. No beeps I thought would mean either dead mobo or dead all components ie CPU, graphics ram.
Here is something that helped me with the exact same problem.
Start off by making sure all your hookups are plugged in
atx+12v+ any other connector
now unplug it from the wall or turn the switch off.
Take all your ram out and put one in the main slot (some it's the 3rd one up)
take your cmos battery out
Hold your power button down for 1min to drain any power left in the board
set it to bios jumper to clear, and wait
after 30min-24hours put your battery back in and move the jumper back into its normal spot
plug in a PS2 keyboard (No a USB one will not work) and hold insert down.
Plug in your PSU
Turn it on and see.
Right I've change the mobo and now its sorta working, keep getting blue screen of death evertime I boot into windows, something about irq driver. I think I will be able to get somewhere now!!! I'll post back any updates or if I get stuck with a problem. Thanks Guys!!!
All back to normal! I've lost my overclock but at least I've got my PC back!
so it was they motherboard ey, still no idea why the mobo fried? or isnt working?
No idea why it fried but at least I'm back, now I just need to buy a better mobo. I'm running a Foxconn mobo which is crap for o/c
Still, I'd give the PS a serious look, check the voltages with the system under full load for about an hour.
I was a bit worried about the PSU, I might get a new one and a new mobo.
I have a good feeling it is either your Motherboard, or your powersupply, since I have suffered from having both problem in the past, either bad luck, or parts getting old, I would say those two are the one's I would focus on the most, try and borrow a powersupply from someone, or if that is not possible, go to a computer store, and get them to test it for you.
the reason ur mobo probably fried was due to a spike in the electricity. not all surge protectors protect against them and they r undetectable. it is actually worth spending the money on a surge protector or ups that protects against energy spikes.
1 - 20 of 20 Posts
