can someone help me with a bios update I'm following instructions on evga website to update bios i downloaded patch file, then i run it , it goes into command prompt and asks if you want to flash press y then enter... then i do that and nothing happens.. Is it updating behind the scenes? will i no when my bios starts to flash i mean nothing is happening and im afriad to turn the pc off or do anything or to try and do it again
__________________
__________________
