1 - 6 of 6 Posts
Hi, so I accidentally spilt salsa inside of my PC (I didn't have the side panel on) and I didn't know there was salsa in there at first, so I tried to power on my PC and it turned on for a second and then turned off. Salsa is on the back of the GPU and a little bit on the Motherboard.
I need help figuring out how to properly fix this and what you think is wrong?
Thank you!
well if there were no sparks that's a good sign.
first clean up the big chunks.
then afterwards clean everything with 99 percent alcohol.
dab don't wipe to avoid messy streaking.
You mean, you replaced the mobo with an entirely new mobo, or you cleaned it and refit the original?
Reactions: Jellystab
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
Did you clean the pc with tortilla, wearing a sombrero, and making a run across the border?
Discussion Starter #6
Cleaned the mobo, but it still didn't work. Bought an entire new mobo. Definitely wore a tortilla though! +Rep for all ^^
1 - 6 of 6 Posts
