Hi, I just installed an intel 80gig SSD. I installed windows 7 on it. Everytime I boot up my computer it says "Windows failed to start" then gives me the option to do a repair restart or start windows normally... I select start windows normally and it works fine... but why is this happening?
One more thing you should know just incase. Right after installing windows to the SSD the first thing i did was plug in a 1TB RevoDrive Hyrbrid SSD directly into a PCIe slot in my motherboard while it was running, and also plugged in a 1TB HDD. The Hybrid Drive shows up in My Computer, but the HDD does not. I have restarted my computer several times since then, and the 1TB HDD will never show up in My Computer as if it weren't plugged in. And I get the Windows Failed to Start message everytime I reboot even though when I press "Start Windows Normally" it works fine.
