1 - 10 of 10 Posts
· ...when you walked in
It is due to something called Load Line Calibration. If enabled, you will experience a higher voltage than what is in the bios. If disabled you will experience lower. You need to find out what the difference is while it is under 100% load and the change the voltage in the bios to compensate for the rise/loss
Ive never had this before though when running 1.53volts.
It runs .1v under. so if its set to 1.55 it reads 1.45 and so on.
Ive discharged the PSU ( left it unplugged for 3 hours ).
Same thing.
Ideas?
If it is this load line calibration could you please elaborate, what actually is happening? Cheers
LLC tries to minimize vdroop (which is I believe, when the core runs under load, the voltage "droops"). It might also try and minimize vdrop, which is the difference in what you see in the bios and in windows. I don't think LLC is really what is causing this drop. It happens regardless, but less if LLC is on.
To answer OP, my understanding of that drop is just something that happens. I dont think anything is wrong, and you can try to enable LLC to minimize that drop (if your motherboard supports it).
I have had that drop in voltage in every mobo I have owned. It is a bit annoying, but I wouldn't worry about it.
· Premium Member
vDroop is the problem, not LLC
vDroop is a known problem on this mobo
1 - 10 of 10 Posts
