1 - 10 of 10 Posts
Old school
Seeing you are running 220FSB now and should be able to go much higher (think 2.8Ghz and up). Did you set your HT to x4 and a divider on your memory? Also your cpu will start needing more vcore.
ASUS A8V-E Deluxe W/WiFi
V = VIA = Suckage = No overclockin'
HAHAA i love that man... you're tiny font makes it even better!
Old school
Allright, see if you can find a DFI LANParty UT NF4 SLI-D it should be within your 150$ budget.
Could of told me that before i got mine.
Anyway got it to 2.4 its the cpu which anit playing ball.
1 - 10 of 10 Posts
