help plz ,system isnt starting
463 16
idk what the issue is and dont know how to fix it ,all i did was restart and nothing is showing up not even post
it all started when i tried to hibernate and it BSODed on it and when i tried to restart it kept restarting and now even though its on it wont do anything...
i even reset the bios
1 - 17 of 17 Posts
If it won't do anything, it's probably the power supply. Reset the breaker on the back and try to boot again. If that doesn't work, it might be dead. If you can, pull out the PSU and replace it with another one. If you don't have one, then you might want to try to RMA it.
Since it did BSoD before the system died, it also could be another hardware issue. Most likely if it was the RAM, you would be able to post, it would just continue to restart. Unless of course, the RAM is completely gone. If it isn't the PSU, my guess is the problem lies within the motherboard or the CPU.
Efficiencycionado
no post at all? how about removing the cmos battery?
Have spare memory? If so, change them out and see if you can boot back up. For whatever reason hibernate and memory can act up (and it's a good way to find out if the memory is working fine, if you can enter the state and come from it without a hiccup [had memory that refused to do this without a stream of errors]).
Efficiencycionado
does the cpu fan spin at least?
Efficiencycionado
had you not overvolted anything? cpu, ram or nb?
just try one stick of ram. If that doesn't work, reset your cmos. If that doesn't work, pull the cmos battery, unplug the PSU, and hit the power button. Leave it like that for about 5 minutes and turn it back on.
You might have to send it back to the manufacturer. I'd shoot them an email and see what they say. I haven't heard good things about MSI's customer service. And it actually doesn't surprise me that it was an MSI board that broke.
1 - 17 of 17 Posts
