Help plz
847 Views 15 Replies 6 Participants Last post by  hanwinting
HOw far can i oc my P4 3.2 C northwood?
buz when i oc it seems to stuck at 3.6 i dunno why. Can someone tell me y? plz!
mobo ASUS P4C 800 e dlx
ram OCZ DDR 500
PSU 500 W
Temp idel 36c
1 - 16 of 16 Posts
ram OCZ DDR 500
PSU 500 W
Temp idel 36c
What kind and model type is your PSU?
did you lock your agp/pci???
3.52 is about a 15mhz overclock on your FSB
and that would push your pci to unstable land or right on the edge
if you can get past that it could be that you forgot to lock your agp/pci bus's
what do u mean?
there is on like AGP/PCI and the options are 66/33, ##/##, ##/## and Auto
which one do i choose?
thnx
66.33 will lock it
k i'll give it a try and let u know if it works
thnx !!!
man that doesnt work!!!! i m really pissed!!!! i have been trying it for hours!!!
*** is wrong !!! y me!! y does it stop at 3.6!!!
someone help me plzzz!!
Yuo doing your Voltage, also try reducing your RAM:CPU ratio so your RAM is underclocked and see what happens then, just to test it's not your RAM.
What is your Vcore set on?? You can go up to 1.7v.
i tried it up to 1.65v
there are three ratio for my ram 266, 320,400, and auto
are those the one i have to set ( to set FSB:RAM)
thnx guys!!
if it is i tried all of those and still doesnt work sigh*
thnx guys!!
If raising the vcore up and you said you tried running the memory at a slower speed (a divider) then you may very well be at the Max OC for either the motherboard or the CPU. I am suprised that you can not get it any higher. I can't think of anything else to try. Like some of the other members said, It could be that your PSU is not able to supply enough power to support a higher OC. Sometimes when you hit a wall like this, it's best to load up defaults and start over.
I have a prescott which use lower voltages but you should try going up to 1.7Volt Max.
Whats your temps on full load at the moment?
Set your Divider to the lowest one, the 266. Turn Spread Spectrum off and that will help your ocing. Also, have a good look around the bios and ask questions about settings you think might help but are unsure of.
thnx archer !!!
thnx sloth i'll give it a try hopefully i dont fry my cpu lol
i'll let u guys know if that works
sigh*
man doesnt work i dont think its the PSU
may be my CPU limit is 3.6 buz in 3dmark 05 systme info it says that my Cpu internal max is 3.6
1 - 16 of 16 Posts
