Machines running Leopard does not have the option for CMD + R as that OS doesn't have a recovery parttion. The best option would be to upgrade to snow Leopard and then to a newer OS like el capitan. Also, make sure the system has 4GB of ram otherwise it will run like crap on anything higher than snow leopard. During the install you can also just format the drive and clean install.
To grab all of her data, you can just copy it to an external drive. In terminal, just use the following:
cp -Rp
press enter and let it do its thing.
cp -Rp
