1 - 4 of 4 Posts
[If nobody knows the answer to my question, a link to another forum I might have better luck on what be fantastic
I am watching a set of video lectures on basic operating system concepts, and I have come to a point where I have become somewhat lost. The code is meant to demonstrate how producer/consumer applications with a buffer works (like computer to a printer) using coend and cobegin structure. The values presented are as follows:
Type item= ; - I think this is meant to be undefined
var buffer= array of [o....n-1] of type item -equals n-1 because the producer process is always consuming at least one type item I think
in, out= 0....n-1
nextp, next c: item;
in=0
out=0
code for producer:
cobegin
producer: begin
repeat
produce an item in nextp;
while (in+1)mod n=out do skip;
buffer [in]= nextp;
in= (n+1) mode n;
until false
end
consumer: begin
repeat
while in=out do skip
next c=buffer [out]
out= (out+1)
consumer item in next;
until false
end
coend
I understand the n equals the number of item places in the buffer, and the var buffer is n-1 because the consumer process is always consuming at least one type item. However, when you start adding equations I find myself just completely lost. Could anybody shed some light on this for me please?
Fan Man
Cobegin and coend are used to create parallel processes. That code seems to contain a series of errors and I believe this is the reason you are not understanding what it does.
Make sure you check the text after you do copy-paste next time
This is what I took down as notes... I believe that errors were included on purpose to demonstrate a point, as the professor in the lecture said that there were two flaws with the code, but I really coudn't understand what was happening with the base code to begin with so I posted this.
I know what cobegin and coend are, but I don't know exactly what is all happening in between.
What language is that? It looks kind of like Pascal. I haven't seen that in almost 20 years.
1 - 4 of 4 Posts
