1 - 13 of 13 Posts
Fresh windows xp home install and SP2.
When I boot my computer with this video card (drivers not yet installed), the screen just artifacts up... I can't get into windows or the bios to mess with anything at all! I put in an old Rage128 ATI card, and it works and boots flawlessly. What should I do? Is the card (1 week old) already garbage?
go to the 9800 soft mod thread thats sticky follow the steps only when you get to the bios part go here http://www.techpowerup.com/bios/
type in the bios you need and flash it
thats how i fixed my 9600 when i oc'ed it and I couldnt even see much like you couldnt
so there is a start ..getjumpin
-rep if helped
Originally Posted by mdameron
I'll rep, but the card is in fact fried. No worky on any machine I put it in, and it's only 1 week old... Not OC'ed
Are u able to return it m8?
Discussion Starter · #6 ·
No sir, I bought it from www.str8buy.com. They had a good price, and I fell for it, but now, no returns. They only sent it with some bubble wrap in an envelope...
I've learned my lesson, NewEgg or ZipZoomFly from now on...
Who the fu*k are these goons if they don't offer a refund??
sounds liek a cooling problem. you should be able to send it back if its faulty , did you e-mail them?
Does the card have a fan on it, and is it turning?
1 - 13 of 13 Posts
