1 - 4 of 4 Posts
Ever since upgrading to the lastest major Windows 10 update a few days ago Ive been getting an annoying notification popping up every few minutes saying the D drive is running out of space:
As far as I know this partition never existed before the update so dont know why its randomly been created! Its 449MB in size (44.7MB free - although theres nothing visible) and created on my main hard drive - a Samsung 840 Pro SSD.
Looking at the Disk Manager it doesnt give me any options to remove the partition etc:
I use Samsungs Over Provisioning feature which explains one of the partitions at least but I havent manually created any others so is a bit strange! Ive run CCleaner and Windows Disk Cleanup. Any ideas what I should do? Should I try formatting the partition then maybe it will let me delete it after? I found theres a regedit to hide the low space notifications, but I would rather find a proper fix ideally (plus I dont want a random drive in the This Computer screen).
Thanks for any help :)
1 - 4 of 4 Posts
