1 - 7 of 7 Posts
How can i remove the black bolts (dunno the right name for it<img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused"> ) holding the plexi glass window ?<br><br>
PIC! : clickable<br><br><a href="http://xs.to/xs.php?h=xs207&d=06403&f=IMG_0022.jpg" target="_blank"><img alt="" src="http://xs207.xs.to/xs207/06403/IMG_0022.jpg.xs.jpg" style="border:0px solid;"></a>
Those are push pins, press out the centre pin then the plexie should pop out
<div>Originally Posted by <strong>frostbite</strong></div>
<div style="font-style:italic;">Those are push pins, press out the centre pin then the plexie should pop out</div>
</td>
</tr></table></div>
but wouldn't they break then ?
<div>Originally Posted by <strong>Blowie</strong></div>
<div style="font-style:italic;">but wouldn't they break then ?</div>
</td>
</tr></table></div>
Should'nt do, just have a steady hand and it should be breeze.
They shouldnt break if your careful with it. Just be gentle with the push pins and they should pop right out and still be reusable. Ifworst comes to worst, you can just use some nice screws to replace them, or you may even be able to find some similar push pins.
Discussion Starter #7
ok found out how to <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
the middle pin you have to push ot and pull it further with your nail (or whatever) then the outher clips has no pressure on it anymore zo you can push those also out with your finger.... leaving them in 1 whole piece for re-use <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /> <br />
<br />
oke, thanks again for the quick responce... im of painting !
1 - 7 of 7 Posts
