I have a WD Caviar SATA HD that is working but I have not loaded SATA drivers. Currently device manager shows Microsoft as the driver provider for the HD so I am assuming it was installed during the XP install. I am guessing I need to update this with the SATA driver supplied with the mobo but the floppy has several different sub-directories and files such that I haven't a clue as to which to use and I have had no luck finding info that gets me to where I need to be. Attached is a screen dump of the directory tree. Maybe one of you know what I should be chasing at this point.
