1 - 6 of 6 Posts
I bought two of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812200944
I have three monitors, an hp using DVI, the other two HANNspree using DVI. I'm using the two StarTech adapters on the HANNspree monitors. I tested all 3 monitors if they worked and they do, but the third never wants to show up no matter what configuration I attempt to do. Everything I have is in working order. Could it be the the gpu I have that is not working? Is there something I'm missing?
Would I have to buy this just to get it to work?
http://www.newegg.com/Product/Product.aspx?Item=N82E16812270113
· Premium Member
You need an active adaptor from display port to dvi
1 - 6 of 6 Posts
