I finally found my overclock of 2.9 with completely safe temperatures. It is stable on orthos (cpu stress) for 12+hrs, and stable on memtest for 12+ tests.
However, when I run the orthos blend test, it fails anywhere between 10 minutes and 2 hrs. I raised the vcore a notch after it failed first and it actually caused orthos blend test to stop quicker.
Any ideas? For now, I will keep raising the vcore to see if that is the problem...
