HELP! suggest GFX CARD
806 Views 23 Replies 12 Participants Last post by  -iceblade^
My friend needs GFX card for casual gaming
CPU-INTEL E7300
MOBO- INTEL DG31PR
whats best?
4770, 9800gtx, 4870, gts 250, gts 260
only one PCIe slot
1 - 20 of 24 Posts
Originally Posted by Tator Tot View Post
The order would go like this
GTX260 ~ HD4870 > 9800GTX+ = GTS250 (these are the same cards) > HD4770
I thought 4770 was bette rthan atleast 9800
well which offers best vfm?
What resolution he plays at would be the determining factor.
I hope there's no bottleneck in the system
we got these options, whats best amongst these?
resolution as good as possible
cool! what about mobo, will it be able to carry on?
gtx 260
gtx 260 or the 4870 (if its the 1gb version) are your best bets from your list.
as for the mobo, you will be fine
The intel mobo has a pcie x16 slot so you are gtg.
and gtx with what amount of ram?
well, 4 gigs should be perfect for it
no 5770? dx 11?
what amount of vram on the GFX?
and suggest me what amount of RAM in my rig?
Originally Posted by el gappo View Post
no 5770? dx 11?
nah these are the only choices
for the GPU, 896. the 1792mb version is a waste of money - not many games use that much memory and i don't think the GPU can use it effectively.
for the PC, 4gb's if you can afford it, 2 if you can't
in that case.. the gts250 will probably be your best bet considering your cpu bottleneck and the huge price difference between that and the 260. expect at-least 50 fps at 1920/1080 4XAA in the latest games
thats cool
The best graphics card out right now for the price is the Radeon 5970. It only cost $600 and is the best for any game.
hey buddy
my choice is limited to 9800, 250, 260, 4870, 4770 only
still thnx for reply
1 - 20 of 24 Posts
