1 - 6 of 6 Posts
STG3 VET
OK Here is the deal I am getting a TJ07
I am just wondering what would be the best way to mount my feser 360 at the top. I want the rad to be internal like my Cosmos S.
Thanks Guy/Gals,
Jason
A.K.A
Juggalo23451
pics and or logs will be appreciated
Totally sold on it being in the top? I'm sure it would fit in the standard bottom area for rad's in a tj07 - on top you are going to have to mod the case a bit, expand the mesh up there for airflow, plus with thickness of feser rad+fans might have some MB clearance issues (forgive me if you've already check on that measurement wise =)
edit: http://www.overclock.net/case-mod-wo...-polarity.html check out oliverw92's new build, looks like he has fans+rad up there in top, haven't read the whole build log ongoing but maybe he'll have in there what he's doing to get that rad up there - if not I wouldn't be surprised if he'd share the info with you; he's always helpful =).
STG3 VET
Yes I am sold on doing the 360 at the top. I plan on putting a 360 rad or 480 rad down below
I'm certain you can put a 480 and 360 in the bottom you can have in one side, out the other. Either CD, or Syrillian did it with his build IIRC.
Edit2: maybe I was imagining it at the time.
STG3 VET
If I have to mount the rad on the outside top I will. I am just trying to get some ideas if anyone has done something like this.
1 - 6 of 6 Posts
